SidecarFlip
Nov 01, 2017Explorer III
agesilaus wrote:Popsie wrote:
I have a vague memory of some folks getting a SCUBA air tank pumped up to very high pressures, then carrying the tank (with a pressure regulator) to quickly and accurately fill RV tires.
Do any of you have experience and/or opinions about this settup?
Amazon
I know of it and the adapters are in the link above. I never did it because I didn't want to carry a tank filled to 3300 psi in the truck bed over some of those roads we go on. I would of had to construct a padded wooden frame or box for the tank. I also did not want to drag a delicate regulator around either. I see there is at least one rig above that eliminates the regulator.
Unless you have a scuba cert card you may have trouble filling a tank tho.
I think any local welding supply place will fill them with non breatheable O2.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
