abom2
Nov 02, 2017Explorer
I have a small horizontal air compressor in my storage area. It will produce up to 150 psi. It is 120V. Small Kipor 2K watt generator will run it without any problems on side of road. (Glad I had it then)
Tank is large enough to fill four tires to 110psi without any problems.
Tank pressure and output pressure are both regulated.
If one did not have a generator to run it while traveling, one could run compressor until tank was a the desired pressure and then use it when needed.
Wife picked my up at a yard sale for $25. Thing looked brand new. I have carried it in my 5th wheel for 8 years now. With my air tools and this compressor replacing bearings, changing tires from road hazards is less strenuous.
The compressor probably weighs 35lbs. It is convenient.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
