stevenal
Nov 02, 2017Nomad II
Chum lee wrote:
In addition, to use a SCUBA tank you'll need some type of VERY reliable pressure regulator which limits the fill pressure to about 150 psi. The standard SCUBA regulator won't work because it's based on the ambient pressure plus what is needed to compensate for breathing at any given depth.
Chum lee
Every regulator I know of works with relative pressure (absolute-ambient). The 1st stage of a SCUBA regulator limits it to 120-150 psig. The second stage drops it to zero relative pressure, which won't help much with a tire. Even 150 might make a tire go boom, but you will have much more control than trying to use tank pressure.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
