Bgtmfsher77's avatar
Bgtmfsher77
Sealant hell
Hey guys. I am needing to reseal the outside of the travel trailer this summer and I’m having a heck of time. All that’s on there now is the original sealant from factory, but it’s hard a rock. My question is, I have tried using plastic scrapers, dap caulk remover and a couple other things and haven’t hardly Got it to budge. I’m scared to use too much more and damage the fiberglass. Do I need to remover all the old sealant even if it’s not really cracked out or can I just go over it with the Proflex? If not, what’s the trick on not spending the entire summer removing old caulking. Thanks guys
  • Thanks guys. I was afraid of that. Some areas are cracked out but a lot of it is not the caulking is just very dirty and unsightly so I want to seal the whole trailer the with the same stuff. I haven’t tried heat yet because I wasn’t sure it would be ok with the fiberglass clear coat. I will try it today and see what happens. Thanks for the tips guys
  • If the old sealant is tight and not cracked, why do you need to reseal the RV? If it is dry, brittle, cracked or losing its seal, then it must be removed.
    I also have a comment on Geocel Proflex. I used it successfully once but had issues the next two times I tried. I got tubes from a hardware store and after a great deal of effort, I found the sealant did not adhere well and I had leaks and sealant peeling off. I got new tubes from Camping World and repeated the process with the same results. In both cases, the material seemed thicker than the first time I had used it. Maybe I got old tubes of material or there was a QC issue. In any case I now use Dicor and will not try Geocel again.
  • they make heat guns hotter than hair dryers BUT try a spot find the right heat setting. and patience, it,ll come loose. you can burn things with a heat gun .
  • Try using a hair dryer to soften the caulk. Mineral spirits can help by lubricating the scraper and then cleaning up the remainder.
  • Have you tried an air chisel?
    :B
    Kidding if course, but some of that stuff seems to need one to get it off....:M
    Not sure what you mean by "five or too budge"
    I've been in the solarium and patio cover business for over 43 yewrs, so I've learned a thing or two about sealing stuff and removing old caulking.
    Going over old sealant with new is the easy way, but the challenge with that is that your new sealing job is only as good as the surface under it. If the old caulking is failing and you put more on top, it will fail too. And it will be unsightly with large amounts showing.
    The only accurate and effective way to do a proper job is to remove the old stuff first and get down to a clean surface.
    Been there, done that. Lots of hard work. I use soft plastic scrapers to avoid damaging surfaces. It helps if the old sealant is very warm. A hair dryer carefully used can help. Just don't get things too hot.
    Paint thinners can remove residual caulk, depending on what the old stuff is made of, but it leaves a residue, as it's petroleum based.
    Acetone cleans all oil based residues off but it will damage painted surfaces if you work it too much. If you use it you absolutely must be very careful not to rub too much, or you will ruin the finish. A fairly wet rag with acetone and a quick wipe cleans. It evaporates fast.
Having RV issues? Connect with others who have been in your shoes.24,237 PostsLatest Activity: Apr 23, 2025
