LarryJM
Sep 24, 2019Explorer II
BreakAes wrote:
But other people have warned me about using Weatherproof Tape like the Eternabond brand. And I read that if there's an issue with the tape, water can get inside it and cause problems, and sometimes screws can eventually poke through it, if you run the tape over screws.
Whoever those "PEOPLE" you referred to IMO are giving you bum advice and I would never listen to them in the future. Also, whatever you are reading I would throw that source out too since unless you trapped moisture under the tape, if it's applied properly water WILL NOT get inside it. FInlly I would put Eternabond at the top of resisting any screw heads penetrating the tape since the microsealant will give a lot so the screw has to really back out a lot to even possibly cause an issue and other "TAPES" IMO will fail light years behind of Eternabond tape.
IMO using any other "TAPE" other than Eternabond is going second rate and I would not recommend it.
Larry
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
