JBarca
Nov 27, 2022Nomad II
pianotuna wrote:
A regular cutoff wheel will make short work of a Kryptonite cable/lock DAMHIK
All one can do is slow the thief down--so they will go to some one else.
I use the same Kryptonite cable through the handle and then through a stabilizer jack. I keep it stored in a Rubber Made bucket with a cover, the cable goes on when it is in the bucket. And the genny is in that bucket all the time, other then when it is running or it is cooling down after running, then goes back in the bucket. And, I roll up the shore line cord.
I "never" leave the site when the generator is running. The genny is unlocked when it is running, but I am in camp then. And when both wife and I take the truck and leave the site, the genny goes back in the truck bed with us in the same Rubber Made tub.
I go by the, out of site, out of mind theory. I do not advertise the genny being left out when it is not running.
And, as was said above, any of this is only going to slow down a real thief wanting it, if they know you have it. If they do not know you have it, as they can't see it, then it betters the odds they will not hit you.
I often see many campers leaving their genny out in the open, shut off, not running, for days on end in the same spot. Their bad luck may run out sooner then mine, I hope.
I'm not sure there is a thief proof way to do this.
Hope this helps
John
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 19, 2026
