CA_Traveler
Dec 16, 2018Explorer III
My Careless power awning started to unwind one day on the interstate. The problem was the very cheap pot metal end cap stripped on the motor shaft flat spot.
Fortunately I saw it - something about checking the rear view mirrors every 7 seconds - pulled over and secured in with ropes. Later it was removed, drilled and pinned. I did find a vendor part with a double flat spot but chose to modify mine.
The awning has a metal cover and as such I believe it's fairly wind resistant to unwinding unless there is a failure like above.
However when parked and extended it has almost no wind resistance. Basically Careless junk.
