mordecai81
Dec 19, 2018Explorer
Esacnj wrote:
I installed 3 of the awning locks shown on travel trailers with manual awnings. On all 3 the hole and pin wound up in a different position (not lining up) each time awning was closed leaving them useless. I contacted the manufacturer several times and got no response.
I've found that the awning length and thus final rolled up and stowed point varies with temperature so the hole you've drilled will end up in a different place if the temp and sun are different from the day you did the install. Installation on two trailers have been close enough but I have had to do some wiggling to get the pin to engage on cold mornings.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
