Dutch_12078
Dec 18, 2021Explorer III
StirCrazy wrote:Dutch_12078 wrote:
Being able to reuse the original wiring when installing the sensors and display makes the job relatively easy as long as there's ready access to the tank walls.
this part isn't so much of a concern as my camper I bought had no monitoring system whats so ever for batteries or holding tanks. so all the wiring I will have to run and such. the tanks are all exposed so easy to put the sensors on. my main concern was how well these lasted.
Steve
If your tanks are close enough together, one of the nice things about the SeeLevel II system is that you only need a single wire plus a ground point to connect all of the tanks except propane. The single wire can be daisy chained from one sensor to the next and on to the monitor. Each sensor is configured to identify the tank it's installed on. The propane tank does need its own wire though since it uses the OEM sending unit.
