theoldwizard1
Mar 13, 2017Explorer II
If nothing came flying out of the crankcase, it MIGHT be rebuildable !
Biggest issue is disconnecting the generator head from the engine. There are a couple of bolts but the problem is disconnecting the crankshaft for the generator rotor. Check YouTube, There are several good video showing how to do this.
Then you can pull the cover off of the engine and see what happened inside.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
