pianotuna's avatar
pianotuna
Nomad III
Sep 02, 2016
Selecting a high wattage psw inverter
Hi,
I'm considering what to buy next to replace the existing inverter which failed yesterday. I need to have 2500 watts but 3000 would be better and it needs must be pure sine wave.
I'm looking for quality names. The three I am aware of are:
Magnum
Outback
Victron
Can anyone add to this list?
  • Hi Smk,
    Yes, I've thought about 24 and 48 volts.
    If I do that I loose any redundancy. Because I stayed with 12 volt when I had a problem, I had a work around in 20 seconds. If I had gone to 24 volt I would have been up the creek without a paddle.
    If I were starting over from scratch I'd lean towards 48.
    But recent events seem to indicate I should stay with 12 volts.
    smkettner wrote:
    Have you considered going 24 volts for this service? IMO over 2000 watts is really pushing 12v system a bit hard.
  • Hi dons2346,
    I have not given up, or Magnum would not be on the list. I'm just curious as to what options may be.
    I also purchased from Imarine.
    dons2346 wrote:
    Don, I think you are giving up on the Magnum to fast. I think they have the best support in the industry plus they speak English. Catastrophic failures can happen with anything so good factory assistance is important
    I really like my 3000 hybrid. The cheapest place to buy any converter is from http://www.imarineusa.com/ The cost of the hybrid 3000 is a little under $1700
  • Don maybe this will interest you
    3000w 12vdc 35/140 amps charge
    12V DC or 120V AC input; 120V AC output (hardwired)
    3000 watts continuous, 4500 watts OverPower™ and 6000 watts DoubleBoost™ inverter output
    3 stage, 35/140 amp selectable wet/dry cell battery charger
    Built-in Isobar® premium AC surge protection and Auto Transfer Switching option for battery backup / UPS operation
    Tested to power inverter standards UL458 (USA) and CSA (Canada)
    High reliability large-transformer design with protected DC and AC wiring terminals
    I have no connections with tripp lite
    just a happy customer with a PVR1250
  • Have you considered going 24 volts for this service? IMO over 2000 watts is really pushing 12v system a bit hard.
  • Don, I think you are giving up on the Magnum to fast. I think they have the best support in the industry plus they speak English. Catastrophic failures can happen with anything so good factory assistance is important
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
