HaulinBass02's avatar
HaulinBass02
Self leveling or no sag sealant for roof seam
I'm getting ready to reseal the edges of my roof where it tucks down behind the drip rail on our TT. My question is would the Dicor no-sag sealant be best for this area or their self leveling sealant? My thought would be the no-sag since it acts more like regular caulking.....and the self-leveling would be what I use on the roof itself when I install my new roof vent?
  • Usually just my wet finger to smooth the bead of sealant
    If i want to cover an area several inches wide, i will use enternabond tape not sealant
  • It will seal on the side trim to where the EPDM goes behind the trim. Because that is a 1/8 inch gap, that DAP will adhere to the EPDM. Just not to use on the roof. NEVER had a problem with it coming loose on small gaps on the side. Doug
  • Mr Wizard, So do you use something like a putty knife if you want it to level out?
  • i prefer NO Sag, every where
    i find it works better for Me!
    self leveling is too thin, runs too much and in some cases flows down and away from what i wanted to seal
    the roof must be absolutely flat and 'LEVEL' or it won't stay where i want it
  • dougrainer wrote:
    http://www.dap.com/dap-products-ph/kwik-seal-plus-kitchen-bath-adhesive-sealant-with-microban-antimicrobial-product-protection/
    This is what I use at home and work. You purchase the clear. It comes out white and dries crystal clear. It is NOT silicone and it does NOT flow like silicone. It is a Adhesive/Sealant. It adheres to Fiberglass/Metal/wood, anything except EPDM roof material. But, it will adhere to where the EPDM rubber goes behind the metal drip/awning rail edge. Coming out white makes sure there are NO gaps and you just use your finger to push into the crevice you are sealing. Then wipe off the excess. You only have about 2 to 3 minutes to wipe off the excess before it starts to partially set up. So, do the sealant is short 3 to 4 foot spots. My only complaint is it dries so clear, customer accuse me of NOT installing sealant around edges and windows/doors I have sealed. I have to poke the sealant with a pencil or pen to show them there IS sealant there. Doug
    If it doesn’t adhere to the EPDM roof then how can you say it is sealing? Dicor adheres to it and ensure nothing can get in there. I could/would use it on the sidewalls etc but don’t trust it to the roof.
  • I’ll use the no-sag then. I’m afraid it’ll just run over the edge of the drip rail.
  • DrewE's avatar
    DrewE
    Explorer III
    For Dicor, if it's sitting on a horizontal surface (or at a joint where a horizontal and vertical surface meet), the self-leveling can be used. If it's a vertical or diagonal surface, don't use the self-leveling kind or it will self-level downwards for quite some distance and make a mess.
  • http://www.dap.com/dap-products-ph/kwik-seal-plus-kitchen-bath-adhesive-sealant-with-microban-antimicrobial-product-protection/
