MEXICOWANDERER
Dec 30, 2017Explorer
A thermobaric weapon is a type of explosive that uses oxygen from the surrounding air to generate a high-temperature explosion, and in practice the blast wave typically produced by such a weapon is of a significantly longer duration than that produced by a conventional condensed explosive. The fuel-air bomb is one of the best-known types of thermobaric weapons.
Most conventional explosives consist of a fuel-oxidizer premix (gunpowder, for example, contains 25% fuel and 75% oxidizer), whereas thermobaric weapons are almost 100% fuel, so thermobaric weapons are significantly more energetic than conventional condensed explosives of equal weight. Their reliance on atmospheric oxygen makes them unsuitable for use underwater, at high altitude, and in adverse weather. They are, however, considerably more destructive when used against field fortifications such as foxholes, tunnels, bunkers, and caves — partly due to the sustained blast wave and partly by consuming the oxygen inside.
In Mexico, they learned the hard way. Most LPG plants are MILES outside city limits. I'm glad I am well away from folks who do not respect what a detonation will damage.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
