doughere
Feb 02, 2014Explorer
30 lbs propane is about 7 gal.
7 gal propane * 95000 BTU/lb * 65% EFFICIENT = 432250 btu
1 AH @ 12V = 12 watts * 3.5 BTU/watt = 42 BTU/AH
432250 BTU / 42 BTU/AH = 10291 AH
If a 30 lb tank lasts 2 weeks, that means you need to harvest 735 AH a day (3 weeks 490 AH a day). You're looking at 1500 to 2000 watts of solar.
This is based on resistance type heat; as SMKEENTR above mentioned, in mild weather a heat pump could provide significantly more heat per watt than resistance.
THINK BIG.
Doug
THINK BIG.
Doug
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
