grizzzman
Apr 26, 2015Explorer
MEXICOWANDERER wrote:
I've been venting about these things for years on this forum. The alternator 3 stator leads are tapped inside the alternator. Depending on the power rating of the alternator (3) 8 gauge or 6 gauge wires are run from the alternator to near the house batteries. This box is installed and wired. The alternator will run about 25% cooler,the regulator and the rectifiers inside the alternator have all the heat relieved and the alternator will last a lot longer. These things are great, with a proven track record of improving alternator reliability and much improved charging ability to motorhome house batteries. The link points to a reasonably-priced external rectifier. The rectifiers in the alternator continues to power the chassis.
External Rectifier
Remote Mounted Alternator Rectifier
A separate additional rectifier relieves a great heat load off of a vehicle's alternator. What it does is develop DC power from the AC (stator) windings in the alternator. Exactly like the "diodes" do inside the alternator.
With a SECOND rectifier, an individual can power the house batteries. If the alternator is being used to say charge house batteries at 90 amps and recharge the engine starting battery at 25 amps, the alternator's "diodes" need only deal with 25 amperes of current passing through them. Instead of heating incoming air 40C over ambient, the temperature increase would be <5C over ambient.
The house batteries thence need no isolator. No solenoid, no blocking diodes, switches, or yadda. There is zero voltage drop, except of course at wire terminations and fasteners.
Voltage Regulation is automatically controlled because the AC leads present exactly the same voltage to alternator and remote mounted rectifier "diodes".
I have manufactured my own separate rectifier systems for 30 years. Only I take it one step further: I eliminate the alternator rectifier bridge as well to increase air flow.
I would personally choose the higher rated rectifier in the link above and then limit the permissible amperage to 130. The built-in fan would be the weak link, and by limiting amperage it would allow convection to help cool the aluminuim heat sinks.
MEX if i were to run a additional #2 wire from the alt to the selunoid would this cause the voltage to be senced by the house batteries? The idea is to have the house battery voltage control the regulator at the alt. Also paralling two 200 amp rectifiers off of ebay. They claim it dosent require heat sinks. Do you believe this would work?
