way2roll
Jul 06, 2022Trailblazer
Sounds like you are engineering a solution in search of a problem. Just manually open and close the valves. You have to manually pull the jugs to fill anyway. Or have a bigger reservoir and use the jugs to fill it up - this is really the entire premise of a fresh water tank in an RV.
Sounds like a lot of work and money but to each his own. Good luck.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
