Jul 06, 2022Explorer II
Tal/IL wrote:I would use an Arduino, latching solenoid valves and a single flow meter. If they are 5 gal jugs, sequence the valves every 4.8 gals metered. You would need either a relay board or MOSFET (SSR) board to drive the solenoids.
Shouldn't be difficult with a Raspberry Pi or Arduino programmed to control a system of water level sensors and actuators/valves
Or better yet, have 1 larger tank to pump the water out of and several smaller, lighter jugs to transfer the water to the larger tank
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
