wildtoad
Jul 07, 2022Explorer II
wnjj wrote:time2roll wrote:
If they are sealed just stack them. The highest pair will empty first so a refill can be made.
This.
Gravity will take care of the issue. Lay them on their side so the exit is at the bottom then stack them one above the other. The separate cans will act like one large one, emptying from the top downward.
Agree. Stack them, have each can feed the one below it, attach pump to the bottom tank. Each can will need an water input and output feed AND an air input valve. Air valve closed on all but the top can. Might want to use translucent cans so you can visually check water levels.
Several types of stackable water containers on Amazon. With minor alterations should do what you want. Let gravity work for you.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
