valhalla360
Jul 07, 2022Navigator
ItsMeOK wrote:
Well to address some of the "comments", this is for a smaller vehicle (Class B Van) so space is at a premium. It's for being able to have a modular system that has an adjustable capacity depending on what the needs for the current trip or for what other people use needs are. Need more water for this type of trip, slide in more cans. People that don't need that much water can use the space for other stuff. I was actually thinking of collapsible containers but was trying to simplify question so the decision could change while on a trip.
It would allow using the oldest water first. Also, you could carry a can in a backpack, etc. into a restroom, etc. and fill one.
A larger built in tank with a 5gal jug you can use for refilling when you can't get the rig close enough to fill directly off a tap would be my recommendation.
- If it's a short trip where you don't need maximum water, you probably don't need maximum storage either.
- If it's a long trip where you need maximum water, you also need maximum storage.
Much simpler than a rube goldberg system with lots of failure points that offers little additional utility.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
