ItsMeOK
Jul 07, 2022Explorer
time2roll wrote:
If the tanks must be level then they just need to be sealed with two tubes. The tube that connects to the next must feed from the bottom. The pump will pull all the water out with the end tank admitting air and empty first. The tanks will empty in sequence.
Thank you. I had thought of that but could not work out if the physics of it would actually work that way. I might have to do a mock up to prove it to myself.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
