Naio
Jun 29, 2015Explorer II
2oldman wrote:Naio wrote:A little difficult to answer without a schematic, but, unless your switch is on the battery interconnect cable, no, they are still connected in series. Whether they're powering anything is irrelevant. Does that answer?
When not in use, the switch is off. Am I correct in thinking that the batteries are not considered to be connected in series at that time?
I hesitate to try to do a schematic in ASCII.
There is a cable connecting A- to B+.
And B- goes to the motor.
But the cable from A+ has a solenoid in it, so it goes nowhere when the solenoid is off.
Does this count as series?
And what exactly is the bad thing that happens if I charge them seperatly?
Or simultaneously, on two 12v charger outputs?
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 20, 2026
