MrWizard
Jun 29, 2015Moderator
The discharging use...is exactly the same for two batteries in series
And recharging in series sends the amps back thru both batteries at the same rate ( or it should )
Can you guarantee that when you recharge them separately, they will be charged at exactly the same rate and voltage for exactly the same amount of time, without any difference in amps, volts, time and battery temp
Use the slow 24v charger , 24 solar system, or a new 24v charger
There is only ONE WAY to do this correctly and insure battery life, series charge with the correct voltage
I understand you want to speed up the recharge process
Do you want to kill the batteries before their time and buy new and start over doing the same thing ?
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 20, 2026
