MrWizard
Jun 29, 2015Moderator
did you buy a "true charge" with (2) outputs ?
then yes you can charge each battery separately, because it will monitor each battery, but you need to remove /disconnect the (inter connect) cable between A- and B+ when connecting the true charge
sorry about your cat..
but erroneous battery statements need to be corrected
using "individual" separate chargers will not be balanced and equal
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 20, 2026
