Naio
Jun 29, 2015Explorer II
MrWizard wrote:
did you buy a "true charge" with (2) outputs ?
I have a NOCO with 3 outputs. I'm not familiar with the 'true charge' Or sometimes I use a single -output charger.
then yes you can charge each battery separately, because it will monitor each battery, but you need to remove /disconnect the (inter connect) cable between A- and B+ when connecting the true charge
sorry about your cat..
but erroneous battery statements need to be corrected
Thanks. And I appreciate the corrections, just not the mean remarks. I am here to learn.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 20, 2026
