wa8yxm
Jun 30, 2015Explorer III
If you use multiple identical single output chargers you will be OK
KEY WORD: IDENTICAL.. They should be smart chargers as well
If you use a multiple out charger with ISOLATED OUTPUTS (most are common negative) you will be ok
If you use a Multi OUt with one lead common to all outputs You will **NOT** BE Ok
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 20, 2026
