dougrainer
Jun 12, 2020Nomad
You must have the Accuslide system. If you have broken a cable 6 times in 14 years, you have an ALIGNMENT problem with the cable pulley's. When correctly adjusted, none of the 8 cables should rub on anything other than the various pulley wheels. Fraying a cable(rubbing then breaking) is caused by the cable/s rubbing on a metal area of the slide box mounts. ANY shop that has worked on Accuslide can repair regardless of OEM. BUT, the question you need to ask is, DO YOU(shop) have experiance in Accuslide systems. If NOT, then find a shop that has. Doug
https://norcoind.com/bal/downloads/accuslide/accuslide_service-manual.pdf
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
