wa8yxm
Jun 13, 2017Explorer III
No the smaller outlet won't damage the RV, though the reverse may not be true.
What damages the RV is high or low voltage. Now. Depending on many things running an A/C on a 20 amp outlet may .. cause low voltage. (Due to voltage drop in the wires and extension cord) but.. If you check the breaker box in the RV for the breker marked AC or Air Conditioner or A/C (how I mark 'em) You will see.. 20 AMPS.. So no a 20 amp circuit is fine for the A/C.
YOu might want to make sure the house batteries are fully charged first though.. (LIke plug in for 2-4 hours) here are some numbers from MY RV yours may vary
A/C #1 13.9 amps A/C #2 13.5 amps (Both are 15000 BTU different maies)
COnverter, with very hungery batteries 10-11 amps
(Total 23-25 amps and CLICK of darkness ensues.
Converter with FULL batteries (or in absorption mode) 1-2 amps. NO click of darkness (With a single A/C running.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
