theoldwizard1
Dec 09, 2017Explorer II
Rootuser wrote:
When the Generator or Shore power is not present, the Inverter will pull from the battery and feed AC power into the AC side of the panel from the batteries.
The question is: How do I power the DC side of the Toy Hauler. All of the lights etc are 12V and they are hooked into a panel that is hooked to the converter.
Disable/remove the converter. Wire the 12V panel directly to the batteries.
With lithium batteries they will not be damaged if you pull them down to ZERO ! What would be handy is a generator auto start if the batteries get down below a certain level.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
