Rootuser
Dec 09, 2017Explorer
MEXICOWANDERER wrote:
South San Francisco Bay Area
Heaven on earth for low-temperature-sensitive lithium chemistry.
I recommend verifying after installation that your charging agrees with the manufacturer of the battery product. And that the battery built-in overdischarge protection works exactly as specified by the battery manufacturer.
Yes sir, the weather in CA as a whole is pretty close to perfect in most places.
I planned a layered approach to protecting the batteries. The BMS will protect the batteries at ring 0, with a voltage regulator circuit up-line at ring 1, and then the charger cut-offs built into the charger. Between those three I should be able to avoid most massive failures.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
