Rootuser
Dec 09, 2017Explorer
Matt_Colie wrote:
Just connect the DC panel to the output of the converter. If you use the DC or the AC from the inverter much, you will want to change that single battery for a pair of golfcart batteries in series.
The reason you connect to the converter output is so you still have lights when the battery is removed.
Matt
Thanks for being the first reply. I had not thought about using the DC with the batteries removed. This would in fact require the converter remain in place. The problem is the converter has a charger that I don't want to use. I believe however the charger I plan to build will do just fine.
I plan to 500-600AH of LifePo4 batteries at this time.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
