GordonThree
Dec 09, 2017Explorer
Higher voltage greatly reduces wiring and switching losses, less current to deliver same wattage.
Also makes pack construction simpler, you don't need super heavy parallel cross-bars.
Replacing failed cells in the "deep desert" is going to be difficult either way. Also no reason you can't wire 4 or 10 12v packs in series if you're set on buying off the shelf.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
