mobeewan
Jul 27, 2015Explorer
If there is no alternative than to replace the 3 x 1/2 x 3 tee, 3 inch waste valve end and grey water adapters you might try cutting the 3 inch 45 degree elbow at the half way point first making it a 22.5 degree elbow and see if a 3 inch 22.5 degree female x female or female x male abs elbow can be glued onto the remaining portion of the 45 degree elbow. Then extend the 3 inch as needed.
Another option is if you already have enough ground clearance, remove the 3 inch cap. Cut off or break off the tabs on the sides of the male bayonet fitting that allows the cap to twist on turning that fitting into a straight adapter. Then glue on a 22.5 degree elbow and then extend the 3 inch pipe as needed.
I did something similar by gluing the below fittings together for my home dump station. I removed the bayonet tabs from the male threaded fitting and then glued the 2 fittings together.
3 inch Male pipe thd x male bayonet fitting
3 inch female glued x male bayonet adapter
I needed a longer 3 inch male pipe thd x male bayonet fitting than the original. My clean out was too deep in the ground for the original. I left these fittings in place and use a female bayonet cap to seal it in lieu of the original threaded plug. I added a cover over the dump station / clean out when done.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 30, 2026
