BFL13 wrote:
2oldman wrote:
The numbers seem fine to me. What's the problem?
CA Traveller was giving me a hard time about a panel having a Vmp of 14V for one thing. I don't know what your BPs are supposed to be compared with what they are. I don't know anymore if it is correct to add the Vmps of mixed panels to come up with the Vmp the controller will choose. We have heard that the controller gets confused about what to choose.
My plan is to wait and see what you get next, and note what others have to say.
remember his panels are in '
series'
it is the amps that must match up not the volts
EXAMPLE if one panel is 4 amps and the rest are 6 amps
the 4 amp panel will restrict the string to 4amps or eventually burn out from trying to carry 6 amps
MATCHING VOLTAGE is for parallel panels
his series panels will have series total addup voltage
if all his panels are within a few 'tenths' in AMPS he should be OK
any significant different say 1/2 amp or more and the circuit will be restricted to the amps ability of the lowest panel
if his lowest panel his 6.5amps and his max panel is 8.2 amps
he will never see over 6.5 amps max input because that panel cannot pass 8 amps
i don't think he has that much difference in his panels
it just an example to show you the way the series circuit works
mppt voltage is based on the output to battery not any individual voltage of a series string
