jheppner
Oct 19, 2019Explorer
We have had the Winegard updated software installed in our dish for Shaw Direct. It worked fine all the way to Laughlin where it decided it couldn't find both satellites so it stowed. I called Winegard and they said when it honed in on "111" I should push the power and select buttons at the same time to lock the dish in. They said DO NOT pull the plug as you will have to have the controller totally re-set. I've been following their instructions and it works fine although I object to paying approximately $500 for software that doesn't do what it was supposed to. At this point, we're not having any problems getting the HD channels although they have a tendency to go missing and then return again. Very puzzling.
