brulaz's avatar
brulaz
Sheared Pin in Slide
Last fall a clevis pin in my slide mechanism sheared off.
I believe it is this one:
W1245027
GR-1547 Clevis Pin 1/4" x 1-1/8" Stainless Steel
found here: http://www.rbwstore.com/Slide-Outs_c_4.html
(although the one that fell out didn't look much like Stainless Steel)
I used a standard (grade 3?) bolt to fix it. Elsewhere I was told to use a grade 8.
Any idea how the shear strength of a 1/4" Stainless Steel clevis pin compares to a grade 3,5 or 8 bolt? (With or without threads?)
The old bolt I put in is still working, probably because we are now very careful when operating the slide. No more on/off jerking. Just start it and wait until it stops by itself.
Guess I could just order some replacements but would probably pay a stupid amount in shipping to Canada.
  • Ranger Smith wrote:
    When I had mine fixed once I was told by a mobile RV tech that it was a special bolt similar to one on a snowblower. It is made to shear so the gearbox does not get destroyed.
    Yes, that;s what I was expecting. But what fell out really did look just like the clevis pin in the link, except it was not new & shiny and didn't look like SS.
  • Stainless bolts are usually soft. I would not use one. Mine snapped one day going out and what to do? dug around until I found a bolt and shoved it in and it still is there today. As to comparing shear pins in snowblowers. Ariens uses a bolt that has been undercut to break in a certain place. Toro uses a grade 8 bolt and feels that their gears are stronger than the bolt. They are right. Grade 8 bolt snapped in half no damage to gears. Back to the camper I believe the bolt I put in was a 10/32 x 2 standard bolt Not anything hardened.
  • When I had mine fixed once I was told by a mobile RV tech that it was a special bolt similar to one on a snowblower. It is made to shear so the gearbox does not get destroyed.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
