ScottG
May 27, 2015Nomad
sealevel ram wrote:ScottG wrote:
But regarding having a ground rod at the box, if you mean at the box where the 30A plug is then no, it should not have one. At the box the ground and neutral should be separate and grounding should only be achieved through the ground rod at the main breaker box.
Guess I was not clear in my original post. I installed a subpanel in the MH garage with three breakers, one of which is for the motorhome outlet.
Maybe but often times I just don't read so clearly. ;)
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
