JPeyton
May 27, 2015Explorer
MEXICOWANDERER wrote:
Lightning striking the earth or anywhere else near transmission or distribution lines can send inductive power up through the GROUND plug then dissipate through the neutral or phase connections. Total and complete disconnection from the grid would be the only reasonable protection against such an event. IOW unplug :)
This. And also you can get the same thru the neutral wire which is (supposed to be) grounded out on the street by the transformer.
You can also get hits thru your computer wireless setup which typically jumps from shielding in any antennas to core (via material permittivity). Best way to fix that is to not ground your computer equip.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
