wa8yxm
May 05, 2014Explorer III
tuna fisher wrote:
I have a Magnetek 6325 what would be the easiest to replace it. I'm not a elect guy but am handy with anything except elect(mental block)? What about just using a seprate battery charge to charge till I replace my Magnetek, thanks to all for your help.I'm leaving in a week to boondock for 2 weeks, need help fast....
You have two choices, The easiest by far is a Progressive Dynamics 9200, you put this .. Elsewhere, in your RV, and remove the converter wire from the breaker on the 6300 Tape and label it.. From the same circuit breaker (you may need to upgrade) run new wire to the new converter.
NOTE: Advantage: Heaven forbid the 9200 fails, You still have the original there and can un-tape and re-connect the wire.
Better (Technically) is the Progressive Dynamics 4600 line, I think they make one in 30 amps, This replaces the "Guts" of the 6300 (The stuff behind the curtain...er, behind the fuse panel)
Having RV issues? Connect with others who have been in your shoes.24,350 PostsLatest Activity: Jan 18, 2026
