Bobbo
May 05, 2014Explorer III
tuna fisher wrote:
I was looking at the PD 4635(35amps) and it states in the manual
"Do not swith higher amp rating than origanl"
The original is 25 amp rating, what say you to that?
Close enough. Not a problem.
What about a Battery minder 2-4-8? I know it's not a new converter but it will save my over chargeing problem.
The 4635 is a better solution, and all you need, and will work just as well as any battery minder. The battery minder won't bulk charge your battery the way the 4635 will. That is important.
Also what are the problems i might have while driving and running my AC with my generator(Honda 2K)?
Should work just fine. I run my AC with my built-in ONAN while driving all the time.
http://www.bestconverter.com/12-volt-2-4-8-Amp-BatteryMinder_p_139.html#.U2gGN9tOW1s
On a semi-related note, I did install a Trik-L-Start on my starting battery to keep it charged. It is equivalent to the 2-4-8 battery minder. It is wonderful. I highly recommend a trickle charger to keep the chassis battery topped off.
Having RV issues? Connect with others who have been in your shoes.24,350 PostsLatest Activity: Jan 18, 2026
