If you have a 30A Shore Power Cable then all you need is a $7 dollar 30A to 15A long dogbone adpater from WALMART...   Looks like this
Then you plug your 30A Shore power cable into this adapter and the other of the adapter then plugs into a 10Gauge extension cord  coming from your garage or house. You can use up to 50-feet of 10Gauge Heavy Duty contractor type (YELLOW) extension cord here.  All three conductors have to be used...  Its best to use the garage and maybe you have a dedicated 20A circuit there for an air compressor etc.   This is best place to get your 120VAC with nothing else on the circuit.
I would use one of these circuit testers the first time to be sure your garage 120VAC source is wired correctly.
AS stated do not plug something in your 120VAC receptacle and plug that into the house (Two male connections)...  that is called a widow maker...  Guess which one is going to be the widow...
You also have a safety ground to consider as well.   The trailer frame ground comes from the shore power connection  which in this case would be coming from your house ground. Otherwise you cold get shocked by standing on the ground and touching the trailer frame.
Lets be safe doing all of this...
Does this make sense from some of the other posts on here commenting about not doing this...
Roy Ken
