Artum_Snowbird
Jul 08, 2018Explorer
Sounds like the batteries are failing. Why are they failing? Well you have to determine whether they have lost the connection to the converter, or if the converter has failed. Put your meter on the converter output positive and negative terminals. If you see 13.6 there, you should see it on the batteries on their positive and negative too. If you don't see it on the batteries, the wires between the converter and the batteries are loose.
In my case, it was the negative wire off the converter that fed to the battery. I jiggled it, and all the lights in the house lit up. Tightened the screws up and it worked forever.
