MrWizard
Jul 09, 2018Moderator
glad you found it and fixed it
apparently you have a 4 blade 50amp rv service ( but you never said yes or no )
it has (2) hots (1) neutral (1) ground
you have this plugged into (3) blade 30amp adapter , plugged into a 30-15 adapter ?
YES or NO ?
we all thought the 50 to 30 had burned out (1) of the hots inside the adapter
rubber dogBone 120v RV adapters, NOT parts inside the RV
you do need to answer the questions that are asked by us
if you don't understand the question, ok, tell us
but we can't help when you don't answer
YES or NO ?
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
