MrWizard
Jul 09, 2018Moderator
just as you found the loose wire in the blue (4) wire female plug
adapters can get hot enough to burn a wire on the inside
your A/C on a 20amp circuit, voltage goes down current goes up, resistance goes up, heat level goes up, its bad spiral that keeps going and getting worse
until something fails
heating the cooling, cycling will cause screws to loosen
as you found out
as you found out
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
