wa8yxm
Jul 28, 2023Explorer III
Shore power or a "Battery maintainer" Such as a Battery Tender.
The answer depends on your converter. A good 3-stage converter like an IOTA with IQ-4 or a Progressive Dynamics with Charge wizard.... (None better) PLUG IN.. by all means PLUG IN.
Magnetek 6300 UPGRADE the converter to one of the above and Plug in
What is it company that bought out Magnetek and improved it. Parallex 7300 Use a maintainer.
Those are examples. What is the difference from worst to best.
The magnetek 6300 had no regulation no "Smarts" it just keeps charging and has a well deserved reputation for killing batteries.
The parallex 7300 and 7300T.. The 7300 is a "Float" charger. IT's ok but the batteries never top off the 7300T has a timed BOOST mode when it first plugs in ... Better but still not much better.
The Progressive Dynamics Wizard or Iota's IQ-4 are 3-stage PLUS converters that sense the battery state and go into BOOST, Absorption or float depending on what's needed.. Now I'm not sure about the IQ-4 (Think it does this) But the Wizard after so many hours of float will go into a short "Equalize" mode which can also extend battery life.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
