opnspaces
Jul 28, 2023Navigator III
You definitely can't answer that question until you know the make and model of the charger. Look on the power distribution center (where all the circuit breakers and fuses are)
Be aware that the battery disconnect switch may not actually disconnect all loads on the battery. So just flipping the switch may still allow the battery to drain and die.
A battery maintainer hooked directly to the battery with the disconnect switch set to disconnect the battery would be you best be until you can determine the make and model of the charger.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
