When connected to shore power it should run everything on the MH correct? In my case (and we are in extreme cold weather in Colorado Springs at present) the furnace will only work when connected to th...
Need to know if you're dealing with a '99 Southwind, or 2012 Newmar, or whatever. OK you have 12 volt power from the batteries. Does any 120 volt accessory work. If so, which ones? Or is the critter make believing it's boondocking?
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
