When connected to shore power it should run everything on the MH correct? In my case (and we are in extreme cold weather in Colorado Springs at present) the furnace will only work when connected to th...
Your shore power is not getting to either the converter or your inverter/charger depending on what you have. Look at the inverter and get make and model, then post it. Look around the 120 volt power distribution panel for information on converter. Turn off all 120 volt circuit breakers in the rig applying light pressure toward off. Then turn main circuit breaker on, then each of the branch breakers one at a time. You could have simply a trip breaker.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
