Pops_RExplorerDec 31, 2014Shore PowerWhen connected to shore power it should run everything on the MH correct? In my case (and we are in extreme cold weather in Colorado Springs at present) the furnace will only work when connected to th...Show More
BFL13Explorer IIDec 31, 2014Your converter is not on. Or if on, no 12v is getting distributed. Just connect/clamp any simple 10 amp or better battery charger to the house batteries and plug it in to your 120v. That will get you by.Now you can take your time to solve the converter problem.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
Related ContentShore power questionGenerator/Shore Power Work, Battery Power Doesn'tShore power plug conversion?Shore Power??DC power vs shore power
