When connected to shore power it should run everything on the MH correct? In my case (and we are in extreme cold weather in Colorado Springs at present) the furnace will only work when connected to th...
Before condemning the converter, verify that it has 120 volts going into it. Verify 12 volts DC is coming out or not. Check reverse polarity fuses in the converter if equipped. If 12 volts DC is leaving the converter, make sure it is getting to the 12 volts DC distribution panel. Check fuses that go to batteries.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
