tntluke's avatar
tntluke
short in overhead lights, porch light & a.c.
When I flip a light switch it is causing another light to go out and I try to turn on another light and the a.c. goes off. DC fuses check out ok. Battery is new.
  • Wire nuts are a source of a lot of electrical problems. Might check the wire nuts in the problem wiring circuit.
    Don
  • Bobbo's avatar
    Bobbo
    Explorer III
    When strange things happen to multiple devices like that, I always first suspect a bad ground somewhere.
  • DrewE's avatar
    DrewE
    Explorer III
    I would suspect a bad ground connection, common to all the circuits in question. Finding the ground...that could be a challenge. Maybe the maker can supply you with a wiring diagram if you're fortunate.
  • normally what is called a 'short circuit' means a power path to ground and blown fuses
    turning on a light and having the A/C shut off means a 'Voltage' problem on the circuit feeding the thermostat
    could be the TS control power is coming off the same circuit as that light switch
    how long have you had this RV, is this a NEW problem
    check the batteries and the converter for loose or dirty connections
    a recent purchase, that the previous owner updated with a newer A/C and TS
    then something might be connected WRONG
  • You have a wiring issue. If I was to guess, one light switch is interrupting power from the thermostat. A further guess would be that some of the lights are interrupted by switches using the (-) phase of the 12 V wiring instead of the correct phasing, using the (+) phase.
